Author Topic: Kiesler 5-speed hyd clutch  (Read 1444 times)
Offline GreenFish
« on: July 06, 2006 - 06:12:13 AM »
who here is running the 5-speed and useing the Hyd. Clutch?  Mine feels very mushy and doesnt seem to grab as hard as it should. THey sent me the Sachs clutch, i am thinking of switching to a McCloud (sp?) i hear they are much better. Hope to chat with keisler about this at carlisle. any input?
Offline Robb
Re: Kiesler 5-speed hyd clutch
« Reply #1 on: July 06, 2006 - 09:25:32 PM »
Got one.  installed and troubleshot it myself
Make sure it isnt getting air in the system.
90* elbow was my weak point.
The one that came with the system fit sloppy so I ended up going to ACE hardware and getting another and it fit a little tighter.
I still had a super slow leak at that 90* elbow on the piston cylinder that is on the firewall, that even though it says not to, (and I called Keisler to say that I was thinking of doing it, and they said "what-eva") I used teflon tape....    I did and it fixed the issue.
might be something to check.
« Last Edit: July 06, 2006 - 09:47:28 PM by Robb »
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline ttmott
« Reply #2 on: July 06, 2006 - 09:34:18 PM »
They set me up with a Spec 3+ clutch and pressure plate.  The Mcleod Street Twin was about double the Spec setup.  Still waiting on the master cylinder; they said it was being redesigned.  Getting all of the air out of the hydraulics is the key...
Offline haplo
  • no i am not
« Reply #3 on: July 09, 2006 - 10:17:50 AM »
I have the Mcloud set up and have had no problems,  :aarg:
« Reply #4 on: July 09, 2006 - 09:28:15 PM »
I use McLeod exclusively
Keisler sucks to deal with ,why are they still in business?
I have used hyd clutch systems in th epast & they work well not familiar with keilsers though
Offline GreenFish
« Reply #5 on: July 13, 2006 - 06:48:34 AM »
I talked to them at Carlisle, they told me pretty much the same thing, Make sure there is no air in the line. They said bleed the hell out of it and then bleed it some more.
Ill check my lines to make sure there is no air getting in.
thanks
Offline SirChandlr
« Reply #6 on: July 20, 2006 - 08:21:26 PM »
keisler hasn't had any available, anyone else make a hydraulic conversion?
« Reply #7 on: July 20, 2006 - 11:35:49 PM »
McLeod & Tilton both have hyd slaves available , I like the McLeod one better
Offline madness
« Reply #8 on: July 21, 2006 - 07:56:51 PM »
whats mcleod charge they must use diffrent throw out
« Reply #9 on: July 22, 2006 - 01:15:32 AM »
it is the $450  range , but it replaces the front brg retainer & pushes on the front of the tranny case
