Author Topic: Engine does'nt sound right.  (Read 1343 times)
Offline Ornamental
  • Oslo, Norway
« on: July 06, 2006 - 11:52:17 AM »
It sounds almost like it's leaking exhaust. I've checked the exhaust manifoild gasket, it's ok.
Now i'm wondering if it's maybe not firing on all cylinders. Before i begin the joyous task of taking out the plugs, or maybe even run off to the local friendly plug wire seller, i'd be happy to get suggestions of what it could be.
Please click on the picture below.
Also, it seems to be a little blacker at the right exhaust port here:
« Last Edit: July 06, 2006 - 12:13:33 PM by Ornamental »
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline ShelbyDogg
Re: Engine does'nt sound right.
« Reply #1 on: July 06, 2006 - 03:33:49 PM »
Get a piece of heater hose or garden hose about 3' long and put one end up to your ear. Use the other end to poke around the engine's exhaust header pipes and collector junctions. If there is an exhaust leak somewhere, you'll find it right away with this method.
« Last Edit: July 07, 2006 - 08:31:11 AM by shelbydogg »
Offline Robb
« Reply #2 on: July 06, 2006 - 06:00:39 PM »
Do you have a coilspring choke system for the carb ?  or factory intake manifold
check that nothing is leaking past the little choke spring "bucket" in the intake manifold (assuming you dont have a block off valley pan)
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline GoodysGotaCuda
« Reply #3 on: July 06, 2006 - 10:31:04 PM »
I've had pinholes form in my headers, gasket may be fine...you check the headers. I'd bet its a exhaust leak...only because ive delt with them FOREVER  :lol:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline moper
« Reply #4 on: July 07, 2006 - 07:46:23 AM »
That's a real header leak. It might be the camera, but it looks like the 3/5 flange is bent from tightening. It's the most common leak, between those 2 ports, where the cnter of the flange buckles and cant hold the pressure on the gasket. I only use the Mr Gasket Ultraseals, and I make sure the flanges are flat every time by running a flat file accross them.
Offline Krazed
« Reply #5 on: July 07, 2006 - 06:28:33 PM »
It sounds to me (And the friend I showed it to) That it's not running on all cylinders. Check that your spark plug wires are in the correct order on your distributor. Also, make sure you're getting spark at the spark plug end.
It sounds too loud to me to be an exhaust leak, but it very well could be. Those can be deceiving and mechanical sounding quite often!
'68 Plymouth Barracuda 340 Formula S
Offline Ravage
  • 1974 318 'Cuda
« Reply #6 on: July 09, 2006 - 08:36:36 AM »
I would also agree that it sounds like an exhaust leak ,but a simple way to determin if a slug isn't firing is to pull the plug wires one at a time while it's running.Using the info from that can direct you closer to the what/where answers.
"I flipped off a box of kittens once..." (Tycho on being evil)
« Reply #7 on: July 09, 2006 - 09:38:42 PM »
Don`t be leaning on the car when you do this ,unless you like shocking experiences
Offline 67Vette427
  • My other car is not a Rambler
« Reply #8 on: July 09, 2006 - 11:17:35 PM »
It does look like you had a leak. The gasket is real thin plus the black residue looks fresh and shouldn't be there if it had sealed properly. Next time if you suspect a leak it can be confirmed before tearing it down by running your fingers near the flanges and you'll feel little hot puffs. Just try not to burn yourself.
When you get it back together again and you still feel you have a misfire problem, throw a rpm meter under the hood and start removing the wires one at a time and look for an rpm drop. Note each cylinder drop. The cylinder with the least drop will be your problem area. Hint: Before doing this pop the wires out and put them in loosely with the engine off so you're not fighting to get them off while doing the test. Also, a set of insulated spark plug wire pliers come in handy to avoid getting zapped.
Good Luck
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Offline Ornamental
  • Oslo, Norway
« Reply #9 on: July 18, 2006 - 05:52:51 PM »
Someone did'nt check the gasket good enough the first time.
D*mned composite Fel-Pro appeared to be ok while it was stuck on the header, but once it came off, it clearly was'nt.
But this thread was'nt meaningless though, at least i got to learn a few good tricks from you guys!  :thumbsup:
***Per Arne***
