Author Topic: Fender patches  (Read 1533 times)
Offline Ravage
  • 1974 318 'Cuda
Fender patches
« on: July 06, 2006 - 02:49:25 PM »
Does anyone know if/where I can get a patch to cover this spot? Should I just get some flat sheet of metal and form it myself?
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Fender patches
« Reply #1 on: July 06, 2006 - 03:03:34 PM »
You are looking for a rear lower quarter.
 http://www.autobodyspecialt.com/  or  http://www.goodmarkindustries.com/
Personally I didn't care for the fit of them and opted to buy an entire quarter.  I needed a front lower also, so it made it easier to justify.  I just cut what I needed off of the new quarter.  Another important point is that the lower quarter patch does not have the tabs that the rear valenence bolts to, where as they are present on the entire quarter patch.
Shipping on a entire quarter will hurt also.  If you want to do the entire quarter, try to find a Goodmark dealer near you and you can avoid the truck freight which is usually arount $100.
Offline EvilTwinATX
Re: Fender patches
« Reply #2 on: July 06, 2006 - 03:09:31 PM »
I would just buy some steetmetal and form it yourself...but you should probably leave the edges alone... those are difficult to do by hand... otherwise look for someone with a partial lower Q-panel... they might let you buy the left overs.
Offline Ravage
  • 1974 318 'Cuda
Re: Fender patches
« Reply #3 on: July 06, 2006 - 07:06:01 PM »
Fortunately the edges seem to be in good shape so I think I will try it with sheetmetal first since my brother can prolly "borrow" some from work  :naughty: and if that fails I didn't lose anything much more than time and can try the patches.Thanks for the input fellas  :bananasmi
Offline 73EStroker
Re: Fender patches
« Reply #4 on: July 06, 2006 - 09:48:18 PM »
Ravage, my recommendation would be to go with the new panel. It is extremely difficult to copy any body lines and the exact shape of the panel if you patch and use bondo filler. You can keep the original tabs from the old panel and attach them to the new when fitting the metal. Another tip is to use a strip of metal behind the butt seam before welding. The metal should be about 2 -3" wide with the seam in the middle. Use aircraft Clecos (basically simulates as a spring pop rivet that can be reused over / over) to hold both sides together and in shape for mig welding. Clecos are available through  www.aircraftspruce.com. They are about $0.35 ea and the pliers are under $20. They are excellent for body work. I know because I built an all metal RV6 aircraft before embarking on my Chally resto.
Best of luck whatever you do
Barry
Barry (Salmon Arm)
Offline 360 'CUDA
Re: Fender patches
« Reply #5 on: July 07, 2006 - 10:39:04 PM »
I made my own on the white car but I will buy patches next time.
They came out OK but by no means perfect
Offline Ravage
  • 1974 318 'Cuda
Re: Fender patches
« Reply #6 on: July 08, 2006 - 06:55:43 AM »
If mine turn out that nice I will be one happy camper.This whole mess started as a "simple re-paint" and I want it back on the road this summer without damaging the wallet too much.My current time projection puts me at finishing in september and has already cost what I was planning on spending and still need to actualy get color on it :-\
