I am no expert,I just know what has worked for me in the past,it didnt really matter what car or truck it was on.The reason I dont like the 160 is in the winter the engine may not get up to a good operating temp which robs horsepower and fuel mileage.Afterall most new engines run at around 220,but they are meant to.I dont want to keep changing the stat for summer or winter so the 180 is my choice,drilled with the 1/8" holes,clutch fan w/shroud and an electric fan on the front with a adj temp switch turning it on.I dont really like flex fans,never had good luck with them.That water wetter additive may help(a little)but i wouldnt expect it to do anything more than help a little with the heat transfer.Its anywhere from 20-50 degrees where i live in the winter and 90-110 in the summer.Dont forget a burp bottle,they can save your engine.The right rad cap is also important.
