Author Topic: torsion bar adjustment  (Read 967 times)
Offline Silver R/T
    • Cardomain personal page
« on: July 09, 2006 - 07:06:44 PM »
Re: torsion bar adjustment
« Reply #1 on: July 09, 2006 - 09:22:33 PM »
what are you trying to do , the bolts can be completely removed if you are disassembling the front suspension if you are lowering the front end you can go almost all the way out
Offline Silver R/T
« Reply #2 on: July 10, 2006 - 12:31:05 AM »
thats what I needed to know, thanks Neil
Offline Silver R/T
« Reply #3 on: July 15, 2006 - 12:10:29 AM »
would it ride on bumpstops if I adjust bolts almost all the way out? I adjusted them almost all the way out and now front end bounces over bumps like lowrider. What shocks would you also recommend?
« Reply #4 on: July 16, 2006 - 12:35:27 AM »
yes it will ride on the bump stops if lowered enough
Shocks depend on what you are doing with the car , Konis are probably the best shocks , QA1 has some good shocks too , KYB are a stiffer ride shock
 Monroe still makes a Gasmatic or sensitrac shock too
Offline Silver R/T
« Reply #5 on: July 16, 2006 - 01:56:37 PM »
would it hurt shocks if car rides on bump stops? What part # of Koni's would be good for 68 Charger?
« Reply #6 on: July 16, 2006 - 02:10:11 PM »
running on the bump stops won`t hurt the shocks , not a good ride that way though
Offline Silver R/T
« Reply #7 on: July 16, 2006 - 06:16:40 PM »
here's how mine sits as of now. Still deciding which shocks to go with
