Author Topic: drill depth on crankshaft for 383/440 for input shaft  (Read 1024 times)
Offline 67Vette427
  • My other car is not a Rambler
« on: July 09, 2006 - 11:07:06 PM »
JUst finished up the new 383 for the Cuda and I need to drill the crank since it had an automatic behind it in its original life. A couple questions:
How deep does the hole need to be?
Is it safe to drill out the crank or should I notch off the tip on the input shaft?
Any other ideas or comments?
I have the pilt bearing in and I mated it once already but the bellhousing wouldn't seal so I pulled it out again and noticed the shaft had marked on the inside of the crank.
Thanks
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Offline Killer_Mopar
Re: drill depth on crankshaft for 383/440 for input shaft
« Reply #1 on: July 10, 2006 - 09:47:21 AM »
The 383 in my car had the same problem and my solution was to cut off the end of the input shaft. I remember reading once that cutting the input shaft was better than drilling the crank because it was less of a risk. Also, go with the roller pilot bearing if you already haven't.
« Reply #2 on: July 11, 2006 - 12:59:24 AM »
what was the distance between the trans & belhousing when it stopped , generally yo uwill only need a 1/4 or so of extra depth
Offline 67Vette427
« Reply #3 on: July 11, 2006 - 09:33:50 AM »
Thanks for the input. I had a 1/8" inch gap approximately. I drilled about an 1/8 off the crank and close to a 1/4 of the input and now I'll see if it works....
« Reply #4 on: July 11, 2006 - 10:19:11 PM »
OK
I would not have cut the input personally
Offline 67Vette427
« Reply #5 on: July 12, 2006 - 10:51:45 AM »
oops, too late  :22yikes: At least its the OD trans... not the original. Next time the motor comes out, if it does I'll change out the shaft.
