Author Topic: slap stick shifter  (Read 1684 times)
Offline 70 rtse
slap stick shifter
« on: July 10, 2006 - 05:33:57 AM »
I have a slap stick shifter changes in every gear hard to get it to stay into park  but it is all loose and dosn't slap found a spring under the console dont know where it goes any one know where to start to fix it and any diagrams on how to repair the shifter.
« Last Edit: July 10, 2006 - 05:39:08 AM by 70 rtse »
Offline tactransman
Re: slap stick shifter
« Reply #1 on: July 10, 2006 - 07:49:24 AM »
 :useless:           :popcorn:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #2 on: July 10, 2006 - 07:55:47 AM »
That's the return spring you found and is very important. I can't post photos as the sites full.
I can post them via photo hosting but that's too much effort at the moment...lol
Check out this link as it has a good photo to help you determine where it goes.
http://cgi.ebay.com/ebaymotors/70-to-74-Cuda-Slap-Stick-Shifter-Reconditioned_W0QQcmdZViewItemQQcategoryZ34208QQihZ004QQitemZ140000442186QQrdZ1QQsspagenameZWDVW
 :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #3 on: July 11, 2006 - 12:47:22 AM »
The spring ypou found is probably the forward linkage spring , it sits with the coil towards the rear & left side ontop of the lower pivot support plate but I really need a pic to show how it sits
Offline falcon50flier
« Reply #4 on: August 15, 2006 - 01:04:06 PM »
Here's a couple pics showing the tension spring on the forward slapstick bellcrank installed. Ignore the Joe Dirt interior, this was the setup to get to the interior shop.
« Last Edit: August 15, 2006 - 01:06:44 PM by falcon50flier »
70 Challenger convertible
518 cid Hemi, TF727, 3.73 Dana 60
Offline 70 rtse
« Reply #5 on: August 19, 2006 - 08:08:25 AM »
I fixed the shifter but dont know how this spring goes to hold it into park is this the right one any close up shots
Thank you
« Last Edit: August 20, 2006 - 06:49:29 AM by 70 rtse »
bbscamp
« Reply #6 on: August 20, 2006 - 06:44:59 PM »
Does this help?
Offline 70 rtse
« Reply #7 on: August 21, 2006 - 07:15:35 AM »
Thank you that does help that means  i have the right spring i will try to work out how it goes :jumping:
