Author Topic: Engine Backfire!!!!  (Read 2781 times)
Re: Engine Backfire!!!!
« Reply #15 on: July 12, 2006 - 11:53:48 PM »
usually that i scaused by lean mixture or lack of accelerater pump shot
Offline JRoss22
  • Member Since 05/08/2005
« Reply #16 on: July 13, 2006 - 01:17:03 AM »
Thanks and now how do i go about fixing that? I kinda dont want to screw up anything in the process. :hyper:
« Reply #17 on: July 13, 2006 - 07:47:43 AM »
check to see if that is th problem first , if it is then you need to by a kit & rebuild the carb
« Reply #18 on: July 13, 2006 - 08:11:00 AM »
Can burnt valves cause backfires? I used to get lots of pops/backfires before replacing my heads, the old heads had burnt exhaust valves.
« Reply #19 on: July 13, 2006 - 09:25:48 AM »
yes , but an exhaust valve cannot cause a backfire into the carb, unless the exhaust valve is not opening due to a worn cam or broken pushrod , either of these is a much more major problem , lets try the easy problems first  :2thumbs:
Offline tactransman
« Reply #20 on: July 13, 2006 - 11:55:21 AM »
You can always resort to the good 'ole compression test. :thumbsup:
Terry-tactransman
Union, Mo.
