Author Topic: Speedo Gage calibration ?  (Read 1797 times)
Offline 74MOPAR
« on: May 19, 2003 - 10:28:00 PM »
My 120 mph non-rallye speedo is reading incorrectly and bouncing. It will read 25 MPH while waiting at a stop sign and usually reads 30+mph too high.
 I have a 73 chassis manual but not a body manual, so the only thing it mentions is aligning the adapter plate under the hold-down fork.  Supposedly it has the original speedo gear in the transmission, and original rear-end gears with approximately correct size tires.
  Before I go ahead and pull the gear and cable, any suggestions ??
  Is there a way to calibrate the gage or sent it to a reputable rebuilder ?
  According to the previous owner it worked just fine a few months prior....
 Thanks.
74 'Cuda + 73 Charger Rally + $$ + assembly= Noble M400
 03 Ram Hemi 4x4
 78 Aspen Super Coupe
Re:Speedo Gage calibration ?
« Reply #1 on: May 20, 2003 - 02:59:59 AM »
Welcome
 The cable & gears is not the problem , if it sits at 25 mph sitting still the guage neeeds to be fixed , Performance car graphics amoung others can restore it for you
Offline 74MOPAR
« Reply #2 on: May 22, 2003 - 10:25:44 PM »
Thanks Chryco,
 guess I'll be pulling the gage then.
See you for Charger.com meet ?
  74MOPAR    {89 MOPAR }
 03 Ram Hemi 4x4
