Tips? Yeah a couple more;
When you take the bearing caps off, never forget which side they came from.
When you move the SG over, move the bearing races with the bearings they rode on.
Before you start, mount a dial indicator against one of the ring teeth, hold the pinion, then rotate the ring gear back and forth to write down the backlash. Install the sure grip and old ring gear back in, then adjust the side load adjusters to get the same reading.
Don't use a gasket on the 8-3/4 mount, only silicone sealer.
