Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Stripped Screw
« previous
next »
Print
Pages: [
1
Author
Topic: Stripped Screw (Read 719 times)
Srobinson4
Jr. Member
Stripped Screw
on:
July 14, 2006 - 09:27:34 PM »
Is it true that the proper way to remove a stripped screw is to drill it out? I am having this problem please help. The screw is locate in the stainless steel trim on my passenger side window.
SRR
Logged
Ravage
Full Member
1974 318 'Cuda
Re: Stripped Screw
Reply #1 on:
July 14, 2006 - 10:00:29 PM »
Personaly I would drill it with a bit smaller than the scew and use an "easy-out" to remove it.Most important part is to not heat it to the point you work harden it ,put a dab of oil on it and work slow and easy
Logged
"I flipped off a box of kittens once..." (Tycho on being evil)
Srobinson4
Jr. Member
Re: Stripped Screw
Reply #2 on:
July 14, 2006 - 10:05:50 PM »
Thanks a bunch.
SRR
Logged
Alaskan_TA
Guest
Re: Stripped Screw
Reply #3 on:
July 14, 2006 - 10:07:26 PM »
If you do try try to drill it out, use a left hand drill bit. They can "hook" and spin the screw out, it would eliminate the need for and easy out.
Barry
Logged
Srobinson4
Jr. Member
Re: Stripped Screw
Reply #4 on:
July 16, 2006 - 10:18:13 AM »
Ravage, I took your advise. These things work like a charm.
SRR
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Stripped Screw
