Got the Tach out of the cluster. I'll try testing it tonight, got my fingers crossed. Looks like most of the wires were left off all the guages. Anyone got a good diagram of what wires go where ?
P.G.
Just found an article on using a 12V battery charger as a signal source. Text follows. Any comments on using it on a Chrysler Tach ?
PREFERRED SIGNAL SOURCE... an inexpensive 12v battery charger can be used as a deadly accurate signal source for the re-cal of your tach. This signal source is so steady and accurate that there is no need to compare the reading with another V-8 calibrated tach. Battery chargers typically use a rectifier bridge to convert the AC power source into DC. This turns the 60 hertz sine wave input into a 120 hertz ripple wave DC output. The ripple wave output is be read as 3600rpm by the stock rotary calibrated RX-7 tach. For a V-6 application, an RX-7 tach should be adjusted to read this signal as 2700rpm. For a V-8 application, adjust your RX-7 tach to read this ripple signal as 1800rpm. Please note that you must use a 12v battery for a power source, and the battery charger as a signal source only. The ground wires for both the battery and the battery charger should be connected to the ground terminal of the tach.
NOTE: Be sure that the RX-7 tach is about the same orientation as when installed, because the re-calibration may be off if done with the face in a horizontal plane.
