on my '73 chally, look inside the front wheel well at the frame forward of the suspension the bumber braces are held on by two large bolts on either side. At the rear follow the fram rails to the back & there are two large nuts, one above the other + a smaller bolt at the bottom pointing up, it is much easyer if you remove the rear valance 1st.
