Author Topic: sending unit question  (Read 2259 times)
Offline BIG MIKE
« on: May 21, 2003 - 01:25:01 AM »
what is the omh reading for a good sending unit?
i have 12(full) and 69 ohms.
Re:sending unit question
« Reply #1 on: May 21, 2003 - 01:50:10 AM »
Tested 1 yesterday but I just checked to make sure the ohm reading changed all the way up the scale but didn`t look at the #s  ::)
Offline BIG MIKE
« Reply #2 on: May 21, 2003 - 01:59:54 AM »
mine changed but when i had it wired to the car the gauge wasn't going like it should??
i just don't have luck with gas gauges i guess ???
« Last Edit: May 21, 2003 - 02:02:07 AM by BIG MIKE »
« Reply #3 on: May 21, 2003 - 05:56:23 PM »
 :) Hey Big Mike,
  The readings that you got on your ohm meter are just about dead on right. The only thing I can think of is to see if the ohm meter was moving slowly as you moved the float up and down. If it was, then the fun begins :P Maybe the ground strap to the unit doesn't have a good connection. Maybe the connectors to your gas gauge are loose. I'm not sure how you would test the gauge itself. Good luck.
Offline BIG MIKE
« Reply #4 on: May 21, 2003 - 11:20:53 PM »
i'm going to replace the gauge anyway but mainly i was trying to see if the sending unit resestor was reading like it should.
see i change the sending unit line from 5/16 to 3/8 for my hemi project. i couldn't see paying about 150.00 for a sending unit i can make. i'll post pictures later.
besides the new one i bought for the duster don't work right (but i never checked the ohms)
« Reply #5 on: May 22, 2003 - 05:54:45 AM »
could be the voltage regulater cuasing the gauge to read incorrectly
