Author Topic: Radiator support difference  (Read 1568 times)
Offline ArcticCuda
    • Pepe
« on: July 19, 2006 - 01:50:58 AM »
Is there difference between 22" and 26" radiator supports? I think there is..??..
 :useless:
I wanna replace my 22" Radiator with bigger one.
« Last Edit: July 19, 2006 - 01:56:31 AM by ArcticCuda »
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
Re: Radiator support difference
« Reply #1 on: July 19, 2006 - 09:47:25 AM »
Just the opening is bigger, On yours you can seen were they cut it for the 26, on the left side you will see a line that runs down stamped on the sheetmetal. I have all the parts if you are in need of them.
later,
Jesse lee
cudaregistry
Offline ShelbyDogg
« Reply #2 on: July 19, 2006 - 04:35:29 PM »
Here you go, $95.
Offline dougs bs23
« Reply #3 on: July 19, 2006 - 05:19:57 PM »
do you have to change out both sides?  I've seen someone advertising on  :ebay: the right side, they say its the only one you need to change?  Seems to me the shroud would get blasted if that were the case,, i dunno,, :banghead:
Offline Challenger6pak
« Reply #4 on: July 19, 2006 - 07:59:39 PM »
Your 22" shroud is offset. When you go to the 26" it is centered.
Offline dougs bs23
« Reply #5 on: July 21, 2006 - 05:55:58 PM »
Ah,, I see,  I'll have to look at mine and see,,, being some bozo put a 26" rad in the car I'm currently working on,, by simply drilling new holes in the existing support,, From what I remember when I pulled it out it was blocked about 2 inches or so on each side.
