looks lie a heat port to heat under the carb , from the factory these were hookd to the engine with tubes from the exhaust manifold , if you are using headers there wil be no place to connect them & even with manifolds you will not be driving this in the winter so you could block the port off or even leave it open with no problems as it should not have a vacuum source there
