Author Topic: Key Switch  (Read 982 times)
Offline basement
Key Switch
« on: July 19, 2006 - 12:31:28 PM »
Can someone tell me how to remove the ignition keyswitch assy. It needs replacing.
oh ya, it's on a 73 challenger. ;D
Thanks
Re: Key Switch
« Reply #1 on: July 19, 2006 - 01:32:54 PM »
you need to remove the wheel , crush can & then remove the lock plate below the trun signal housing there is a push button under the lock plate & the plate that holds the spring loaded tab that locks the lock plate , if you have a service  manual it will show where it si better than I can describe it
