I would prefer to see 5 or 6 PSI. You are kind of pushing it at 8 PSI. If your car is running fine, then I guess you are good to go. Otherwise, gas would be forced down your carb., and I think you would notice it running bad.
EDIT- I have a hi-volume mechanical pump. At start-up, I generally am getting 8-9 PSI. Once I drive it around, it drops to 5-6 PSI, which is where I have my regulator adjusted for. If you are getting 8 PSI at start-up, then your's is probably dropping a little like mine too.
