Author Topic: Need Help Identifying Firewall Mount Memory Failing  (Read 992 times)
Offline 70GranCoupe
  • I am not a llama, I am a man!
« on: July 22, 2006 - 04:32:01 AM »
Hi Everyone!
I am working oon repairing some rust in my '70 Barracuda firewall and seem to have forgotten what gets mounted by a couple of screws to it. The general location is to the right of the e-brake setup and left of where the brake pedal set up. Please see pic.
1- My Barracuda has 2 screws that mount ________________???? Anyone know what these screws mount? The '74 Challenger donor car has the same mounting place but no holes or screws.
2- Also why the Barracuda has them but not the Challenger?
Alaskan_TA
Re: Need Help Identifying Firewall Mount Memory Failing
« Reply #1 on: July 22, 2006 - 08:41:16 PM »
It looks like the right area to mount the manual foot washer pump to me.
Barry
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: July 22, 2006 - 09:02:08 PM »
if you have other goofy gran coupe questions, I've got one too (assuming on your login name) along with a lot of pics
Offline 70GranCoupe
« Reply #3 on: July 23, 2006 - 09:07:08 AM »
Hi Barry, are you sure this is for the manual washer pump?
I have an electric washer pump.
Sean
Alaskan_TA
« Reply #4 on: July 23, 2006 - 09:19:26 AM »
My T/A has two screws in the same spot, but there is nothing attached to them. If the holes were pre-punched they may have just put screws in them to close the holes?
T/Ake care,
Barry
Offline 70GranCoupe
« Reply #5 on: July 23, 2006 - 09:24:49 AM »
Hey Barry awesome, that's exactly what I wanted to hear! No wonder I can't remember what went there! And it makes sense that the sheetmetal I am using from the '74 Challenger wouldn't have those holes. I may have some more numbers for yer registry, I have to check out the numbers on the parts car I got the cowl/firewall from if it isn't already listed. Thanks again! Sean
