Author Topic: Need help with hesitation  (Read 1060 times)
Offline AllGreen70RT
« on: July 22, 2006 - 09:30:24 PM »
I'm having problem with hesitation during acceleration. Was running fine prior to some work I did. I'm wondering if I created the problem. Car idles fine. Its a 440 with dual point distributor and Holley 3310. I changed the jets in the primary from 72 to 68 (did remove the carb to do this). Removed the manual choke with the intention to replace it with a Holley electric choke kit. But put the manual choke back on after having problems with Summit and Holley trying to get a kit with all the parts (took 4 tries). Replaced fuel filter. Have not found any vacuum leaks. Any suggestions?
Thanks in advance
Offline 71383bee
Re: Need help with hesitation
« Reply #1 on: July 22, 2006 - 09:44:40 PM »
Where is the hesitation happening.  Rolling from a stop, hard launch, normal acceleration?
I have found that initial timing can play a significant role in this...but since you said you just worked on the carb you are probably right in focusing on that.
71 - 383 FC7 Super Bee
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: July 23, 2006 - 12:44:20 AM »
I'm with 71383bee, when does this happen? and also, is it better/worse hot or cold? Start with the simple stuff, you took the bowl off to change the jets, anytime you take the bowl off a holley, recheck the float level with the engine running, also check your accelerator pump adjustments, make sure the choke is fully open with the engine warmed up.
« Reply #3 on: July 23, 2006 - 02:01:19 AM »
A leaner mix , change in the idle mix screws or lower float level can cause the stumble , you may just need more accelerator pump squirt with the smaller jetting
