Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Removing heads and intake?
« previous
next »
Print
Pages: [
1
Author
Topic: Removing heads and intake? (Read 718 times)
JRoss22
Jr. Member
Member Since 05/08/2005
on:
July 23, 2006 - 01:11:30 PM »
I was just wondering what steps need to be taken to remove my intake and heads? As I am trying to trouble shoot my backfiring issue and I think it could be a stuck valve.
Logged
ShelbyDogg
Sr. Resident
Re: Removing heads and intake?
Reply #1 on:
July 23, 2006 - 09:07:40 PM »
Wait!
Use the Loan-a-Tool at AutoZone and get a compression tester first. Use it on every cylinder to check the compression. That will tell you if you have a bad valve. This might save you lots of time and money.
Logged
JRoss22
Jr. Member
Reply #2 on:
July 23, 2006 - 10:22:44 PM »
Thanks I might borrow one from a co-worker then and use it although I had just done a compression test before installing the new spark plugs. The problem came around after the new carb came on when it was running on all 8 cylinders instead of 4.
Logged
ShelbyDogg
Sr. Resident
Reply #3 on:
July 24, 2006 - 07:14:24 AM »
I still think you have a bad cap or wires or have a wire crossed if this problem didn't pop up till after you changed the carb and plugs. Have you had a "CAR GUY" look at it yet?
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
