Author Topic: 73 Challenger Turn Signal Flasher Location?  (Read 4914 times)
Offline MJS73
    • Mike's 1973 Challenger
« on: July 23, 2006 - 03:48:38 PM »
Can someone point out where it is?
Thanks,
www.mikes73.com
Offline pink panther
Re: 73 Challenger Turn Signal Flasher Location?
« Reply #1 on: July 23, 2006 - 03:56:38 PM »
look about half way across the dash (by your vent knobs) on the underneath side  I can take a pic for you if you like.
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
« Reply #2 on: July 23, 2006 - 03:59:54 PM »
I think it's attached along side of the ash tray frame under the dash. The other is close to the steering column on the underside frame close to the fuse box.
« Last Edit: July 23, 2006 - 04:03:04 PM by fishn4cuda »
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: July 23, 2006 - 04:45:53 PM »
I like that first pic! Now I know where the flasher is supposed to be!
Tom
Tom
Offline MJS73
« Reply #4 on: July 23, 2006 - 05:55:30 PM »
Thanks guys!
www.mikes73.com
Offline ShelbyDogg
« Reply #5 on: July 23, 2006 - 09:33:05 PM »
Thats where I kept telling Cody to look but his ended up being on the other side o the glove box. So if it's not there on the other side.  Plus I also found an extended connector with an inline fuse to the flasher. Something to check if you don't flash.
Offline Cuda Cody
  • Vancouver, WA
« Reply #6 on: July 23, 2006 - 09:37:40 PM »
Yep, I think someone might have moved mine over to the other side.  Rob helped me find it.
It did have an inline fuse, but I think it was aftermarket and I'm taking it out.
Offline ShelbyDogg
« Reply #7 on: July 23, 2006 - 10:06:50 PM »
Cody, I think that inline fuse was a factory fix.  I have one too with the correct connector on one end for the flasher and the other end is a female for the flasher plug. Don't just take it out, just remember that a fuse is there.
It probably corrected a non-fused circuit that fried.
Offline Cuda Cody
  • Vancouver, WA
« Reply #8 on: July 23, 2006 - 10:52:53 PM »
Good point.
I went and looked and my ash tray and the reason the flasher is not on the side is because the speaker crossover is mounted right there.  Where should the crossover be mounted and is a crossover needed for a 3 speaker dash?
Offline ShelbyDogg
« Reply #9 on: July 24, 2006 - 06:33:52 AM »
The crossover box was always used for the 3-speaker dash but I didn't use mine so I don't know where it mounted. I posted some wiring pics a while back from the manual.
« Reply #10 on: July 24, 2006 - 06:53:35 AM »
My crossover box was just sitting to the left of the glove box. Sorta right above where the map light would be.
Offline MJS73
« Reply #11 on: July 30, 2006 - 04:19:22 PM »
Has anyone seen a 3-prong flasher?  Mine is about 13/16" in diameter, 1-3/8" long (not counting prongs) and has 3 prongs.  The parts stores all say it should be a 2-prong flasher.  I can post a picture, if desired.
www.mikes73.com
Offline 422STROKER
« Reply #12 on: July 30, 2006 - 05:18:17 PM »
Sounds like the key in ignition relay for lights  it's a delay fuse of some sort  I got one on ebay for @10 kind of an oddball to find.
Tom
Tom
