Author Topic: Rallye dash lites .....Cuda  (Read 1327 times)
Offline cuda-cable
  • MOPAR or no car
« on: July 23, 2006 - 09:33:36 PM »
Ihave a blue  lite  thats on the top left of the dash/instrument cluster  that now  seems to stay on all the time? it lites the headlite switch area  or is it on a timer of sorts?  Also are the gages  'back lit'   or  only  from the front by the blue panels  in the top of the dash pad area?
I  have a washer bottle  with the electric  pump  ......how does it get wired in,  does it hook to the wiper switch to activate when pushed? .......thx....dk
Offline ShelbyDogg
Re: Rallye dash lites .....Cuda
« Reply #1 on: July 23, 2006 - 10:13:26 PM »
Does you car have an ignition key light? a map light? Sometimes the light group had that upper left light on the little timer circuit with the key light. If you don't, it should be hooked up to the other blue lights for the dash.
Washer pump,  If you had a manual pump, then you have to add the wire that goes to it from the dash switch. If your dash switch has and empty connector use a test light to see if it goes hot when depressed, connect to this wire. If you don't have an empty spot, the wire may be already run to the firewall and you can just add to it's plug.
« Reply #2 on: July 24, 2006 - 02:18:33 AM »
the guages are fron tlit only , 3 lights for std dash , 4 for ralley , the spare bulb could be for the heater control , but it still should not stay on
Offline cuda-cable
  • MOPAR or no car
« Reply #3 on: July 24, 2006 - 08:43:21 PM »
Thx  for the input  to my questions........most helpful  to get this back together since i  bought the project 13 yrs ago  as a pile of parts.......  will post   pics  soon
Offline PlumCrazy
« Reply #4 on: July 27, 2006 - 11:16:30 AM »
The light that lights up the switch panel is part of the Light group package and is on a timer.
Offline sleepyhead416
« Reply #5 on: September 20, 2006 - 06:04:42 PM »
What else belongs to that light group package?  ashtray?  glovebox? that extrablue light? where is the timer switch?  wireing diagrahm?
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: September 20, 2006 - 10:38:44 PM »
For a 1970 Challenger you can check this page, code A01.  Not sure which car you're refering to though.
http://www.stockmopar.com/_images/brochures/1970-dodge-challenger-dealer-brochure/original/1970-dodge-challenger-dealer-brochure-11.jpg
