Author Topic: Question for Challenger owners!  (Read 902 times)
Offline rtgambit
  • Member since March 31, 2003
« on: July 25, 2006 - 09:45:59 AM »
Hey Everybody!
I'm in a bit of a snag in the Dark Horse project. At the moment I'm trying to make sure I get the bottoms of the quarters in the right location. I'm using my current rear valence to get everything lined up, but it's in pretty rough shape, and therefore suspect.
Here's where you guys come in. I'd really appreciate it if a few of you could measure the distance from the bottom edge of one quarter to the other. Mainly I need the distance from the bottom valence hole in the quarter, that way I can be reasonably sure that mine is pretty close (in case I need to pick up a replacement valence).
TIA!
Matthew
1967 Dodge Dart GT
1971 Dodge Challenger R/T
2014 Ram 1500
Offline EvilTwinATX
Re: Question for Challenger owners!
« Reply #1 on: July 25, 2006 - 10:02:38 AM »
can you post pics of the measurement you need? I can do this in a day to two...
Offline ShelbyDogg
« Reply #2 on: July 25, 2006 - 01:06:38 PM »
I would wait till I found an original valance, dented or not, then use it as a guideline.  Some of the aftermarket ones aren't the same and the aftermarkek quarter's are off too. When I put on my quarters, I left the original part that bolts to the valance and welded on to it.
« Reply #3 on: July 25, 2006 - 04:38:19 PM »
 :popcorn:
Offline rtgambit
« Reply #4 on: July 25, 2006 - 04:48:44 PM »
 :bigsmile:
Here's the section I was talking about. It's where the bottom part of the rear valence bolts to the bottom of the quarters.
« Last Edit: July 26, 2006 - 09:36:19 PM by 4Cruizn »
Matthew
1967 Dodge Dart GT
2014 Ram 1500
« Reply #5 on: July 25, 2006 - 05:08:15 PM »
From bottom hole to bottom hole I get 4'10" on my '73 Chally. I also measured from the bottom of the bolt that hold the shackle to the frame and got 7.25" to the bottom hole & 6" to the center hole. Hope this helps.
Offline Clro
« Reply #6 on: July 26, 2006 - 07:37:59 PM »
I got 4'10" from the lower bolts as well. 6" from the lowest hole to the middle hole and 7.5" to the top. Oh yeah that's on a 70 CHallenger with an original valance.
Offline rtgambit
« Reply #7 on: July 28, 2006 - 09:44:26 PM »
Sweet!! Thanks guys! This really helps me out!
Matthew
1967 Dodge Dart GT
2014 Ram 1500
