Indian, the original 15 inch tires on the R/T's were F60-15's bias plys, and i believe the closest metric size is a 245-60-15. I do believe the 245's are a little bit bigger, and the 235's would be a little smaller. Being a radial tire, the sidewalls will be not as high as a bias ply tire. On some e-bodies, the 245's will rub the frame rail behind the tire at full lock on the front, and some won't. Seems to be hit or miss, I've had both happen to me.
