There were 3 rear ends used in e-bodies. Dana 60 (9-3/4), Banjo (8-3/4), and 7-1/4. Only the 8-3/4 had the removable center sections. Those center sections were available with 3 different cases and pinion sizes marked with numbers ending in 741( 1-1/4 pinion) the 742(1-3/4" Pinion), and the 489(1-7/8 pinon). Mopar called their posi a "sure grip" and there were 2 different style units, one with rebuildable clutches, the other with non-rebuildable cones.
The number on the ring gear states it's gear ratio. i.e. 3:23, 3:55.
