ED, for what it's worth, here are measurements from an OE shroud I believe came off a 71 b-body big block. googled the part #3673820 & only got a hit on A-body. overall width 26 1/2", width at mounting tabs 27", at center of mounting holes 25 3/4",
height of sides 18 3/8", top mtg hole 2 7/8", bottom hole 15 1/8", dia. of opening 20 1/2", offset on long side/drivers 4 1/2".
You might check these #s against your repro piece just to make sure.
