News:
You haven't had any milling done (deck or head surface) where the dowel pin is too long now keeping the gasket from getting clamped good in that spot have you?
Are you using factory bolts? Are there any marks on the dowels say from vice grips or anything? with the thicker head gaskets (factory is stamped steel like the MPs) the dowels shouldnt be anywhere near bottoming out in the head. Have you tapped out every head bolt hole with a bottoming tap? (not one that's tapered..the bottoming ones are almost flat like an end mill) Do you use a torque wrech, and tighten in the proper steps and sequence? You should be going in 3 steps. IIRC, the final spec is 85 pound feet. So, tap the holes and blow them out with compressed air. Wire wheel the bolts themselves to get any crud out of the threads. Use 30W oil (not 10-40, 10-30 would be ok) on the threads, and only a little, dont get it all over the place. No finger prints or grease allowed on the head or block gasket surfaces. Clean it with a clean paper towel or lint free rag, then dont touch either surface with your hands. Put the head in place, start with the center bolts (I start all the bolts by hand as far as I can go) and torque them all to 40 pound feet. Then go back, torque them all to 65. Then finally go back and get them all to 85 in a smooth motion. I've done over 50 engiens this way, and never had a leak or blown gasket due to "normal" use. (NOS will kill the small block ones tho..
Something drastically wrong. Never lost a head gasket on a BB Mopar, EVER ! Same spot both times ? and you swapped blocks ? Must be the head !
Bump the above, you check the dowel ?
