Author Topic: pick me a double pumper  (Read 1716 times)
Offline redelliott
« on: July 27, 2006 - 09:32:24 PM »
340  4 speed  3.55 rear comp xe 274 cam 235@.50 491 lift roughly 1 5/8 headers  stock intake what size would you guys run?
Offline 360 'CUDA
Re: pick me a double pumper
« Reply #1 on: July 27, 2006 - 10:33:38 PM »
750 vacuum DP
I know lotsof folks would say Demon but I'm cheap so I would just slap an old holly together and have fun
« Reply #2 on: July 28, 2006 - 01:21:20 AM »
Holley Street HP series 750 DP
 I have used a lot of these carbs since they came out , very responsive !!
« Reply #3 on: July 28, 2006 - 01:23:01 AM »
750 vacuum DP
 What is a Vacuum DP ???, you can have on or the other but not both  :smilielol:
« Reply #4 on: July 28, 2006 - 03:19:26 AM »
  :smilielol:  :roflsmiley:
750 sounds like the right size. DP's are mechanical carbs only.
Offline gomopar440
« Reply #5 on: July 28, 2006 - 05:47:53 AM »
Maybe he means one with a vacuum choke? :dunno:
« Reply #6 on: July 28, 2006 - 10:18:26 AM »
or vacuum advance ?
Offline moper
« Reply #7 on: July 28, 2006 - 02:00:45 PM »
Well, old school wise, I'd go 3310 750 (vaccum secondary) for a mild engine, mild gearing, or a 670 street Avenger VS. If you had to have a DP, I'd run a 4150 DP. Other choices are 625 Road Demon vaccum secondary, or 650 Speed Demon.  The Avengers and Demons are flowed wet, so they are a true real world rating for airflow. The old Holleys are dry flowed, and truthfully flow about 10% less when on an engine and full of fuel. Demons are not Holleys, and can be a little finicky to get "right", but they are a better carburetor IMO.
Offline 360 'CUDA
« Reply #8 on: July 28, 2006 - 07:56:27 PM »
Got me on that one...   :-[  I guess I was talking about dual feed..
750 though
« Last Edit: July 28, 2006 - 08:17:25 PM by 'CUDA360 »
Offline EVIL72
« Reply #9 on: July 28, 2006 - 11:25:22 PM »
750 vacuum DP
I just figured he ment either a 750 Holley Vacuum Secondary OR a 750 Holley Double Pumper  :dunno:
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline 360 'CUDA
« Reply #10 on: July 28, 2006 - 11:46:43 PM »
I have the Carter on mine mostly for the emmisions since the white car is by no means a race car.
I have the holly 750 Double pumper annular discharge on the old race car.  Talk about a carb that dumps buckets of gas
Offline Carlwalski
« Reply #11 on: July 28, 2006 - 11:53:25 PM »
Another thing I've heard about Holley's are while some may find them hard to tune and others find them easy, it's the way they seem to de-tune themselves after time and on many occasions a short period of time too.
Ah, I "did" have a post here before this one. :sly: :clueless:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline R/T
  • Johnson City TN
« Reply #12 on: July 29, 2006 - 07:00:10 AM »
Here is a pic of mine . It is a Holley 750 DP but for the life of me I can't remember the part #
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline 422STROKER
  • Member Since 6/3/06
« Reply #13 on: July 29, 2006 - 08:21:57 AM »
I've also had probs w/holley and the float adj once it's right the thing runs nice  when it's bad it's bad.  The first date I took my now wife on in my Gran Coupe the adj was out and I had to bust out the BIG Screwdriver and a 9/16" wrench She must have been wondering what the h*ll is going on--12 yrs later she knows it's a Disease(MOPARS)!
Tom
Tom
« Reply #14 on: July 29, 2006 - 08:43:50 AM »
The street HP carb is 82751
« Last Edit: July 29, 2006 - 08:49:07 AM by Chryco Psycho »
