Author Topic: pick me a double pumper  (Read 1715 times)
Offline heminut
Re: pick me a double pumper
« Reply #15 on: August 01, 2006 - 11:37:23 AM »
Here is a pic of mine . It is a Holley 750 DP but for the life of me I can't remember the part #
That's not a double pumper, it's a vacuum secondary carb. You can just see the vacuum pod on the passenger side of the carb, and the rear fuel bowl has a metering plate, not a metering block. All double pumpers have metering blocks on both front and rear bowls.
1970 5.7 Hemi Cuda
Oldschool
« Reply #16 on: August 01, 2006 - 11:42:41 AM »
I would recommend either the model Chryco mentioned or a 750 dual line. double pumper.  I run 2 of the 4150 series 750 DL-DP carbs on the Beast and they are VERY responsive, idle well, easily tuneable, and run like a scalded dawg!
Offline redelliott
« Reply #17 on: August 03, 2006 - 07:54:42 PM »
thanks guys i went with a 750 dp #4779  its a little rich to start but i havent had time to play with it yet. i will say it looks damn good on the little 340. i 'm new to tuning so whats the best book on holley dps? looking for street tuning more than all drags. :burnout:
Oldschool
« Reply #18 on: August 03, 2006 - 08:02:19 PM »
Without spending any more $$$, here is a link to a Cliff's notes on Holley tuning.   Hope it helps ya out at least a little...    :cooldancing:
http://www.bob2000.com/carb.htm
