Author Topic: SB or BB  (Read 3536 times)
Offline svitaks
SB or BB
« on: July 29, 2006 - 07:49:30 PM »
my recently purchased 71 challenger has a 318 that lost oil pressure. so i'm forced to choose between replacing it w/ a later 80s 360 or a 440.  i know 360 can make some rediculous power but i've never had a bb car before so i figured this might be my chance. if i went w/ the sb would i ever regret it or want the torque of a bb.  the motor would be overhauld and upgraded.  so what is everyones thoughts.  anyone ever been in this situation? thanks for any input.
Offline Morris'_Mopars
Re: SB or BB
« Reply #1 on: July 29, 2006 - 08:13:54 PM »
440  :2thumbs:
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Re: SB or BB
« Reply #2 on: July 29, 2006 - 08:26:57 PM »
GO FOR IT, just know you will have to replace/alter just about eveything else.
Offline Carlwalski
Re: SB or BB
« Reply #3 on: July 29, 2006 - 08:31:35 PM »
440.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Re: SB or BB
« Reply #4 on: July 29, 2006 - 09:16:48 PM »
Without a doubt 440
SOLD
Offline ShelbyDogg
Re: SB or BB
« Reply #5 on: July 29, 2006 - 09:37:14 PM »
440 or 500 inch "B" engine. Faster revs.
Offline matt63
Re: SB or BB
« Reply #6 on: July 29, 2006 - 09:57:02 PM »
If you go big block it might be nice to find a complete motor/tranny with all of the accessories and brackets, mounts, etc to simplify things.
Matt in Edmonton
'68 Valiant
Re: SB or BB
« Reply #7 on: July 30, 2006 - 05:13:28 AM »
It sounds like you want to go big block. You'll need a different radiator, engine mounts, and I'm sure a few other things. This is a common swap though.
Offline 422STROKER
  • Member Since 6/3/06
Re: SB or BB
« Reply #8 on: July 30, 2006 - 06:22:08 AM »
Why not be different and build a SB Stroker and surprise a few BB sleeping at the wheel.  LOL :burnout:
Tom
Tom
Offline cudabuyer
Re: SB or BB
« Reply #9 on: July 30, 2006 - 06:52:44 AM »
BIG BLOCK
70 Dodge Challenger Convertible 6.1 Hemi
Offline Carlwalski
Re: SB or BB
« Reply #10 on: July 30, 2006 - 08:41:44 AM »
Tom
...Or, use that Stroker money on the Big Block and surprise a few HEMIs.  :smokin:
Re: SB or BB
« Reply #11 on: July 30, 2006 - 09:06:51 AM »
Offline ShelbyDogg
Re: SB or BB
« Reply #12 on: July 30, 2006 - 09:12:12 AM »
Bullit,
That truck block is a 77 year 440. It might be a cast crank. Not that I would turn down a cast crank 440, but for the same build cost, I would try to find a steel crank. If I couldn't find one, I would 440Source a steel stroker crank.
Offline matt63
Re: SB or BB
« Reply #13 on: July 30, 2006 - 02:03:02 PM »
Tom
That's my combination - 408 stroker - 460 hp and much lighter especially with the Eddy heads.
Matt in Edmonton
'68 Valiant
Offline GoodysGotaCuda
Re: SB or BB
« Reply #14 on: July 30, 2006 - 02:28:22 PM »
Most would go with a big block. If i was in that situation i probably would too. Figuring my situation im upgrading from a 318 to 360. Mostly because everything i have is ready for it. The rebuilt trans, rear, gearing is right, mity mounts, radiator, etc, etc. It would be a waste of some parts to put a bb in my car. I'll be closely copying a combo that turns 114mph in a 3400lb 'Cuda in the 1/4.  :grinyes: So either way you can make it fast, for now i like my small blocks. But it seems like you would have not much to loose to go to a Big block  :naughty: :2thumbs:
1976 Dodge Warlock
Wheel & Tire Specs:Link
