Author Topic: tranmission prices  (Read 1394 times)
Offline 440_72cuda
tranmission prices
« on: July 29, 2006 - 08:16:12 PM »
whats the going rate for a used 18 spline hemi 4 speed transmission?
thanks in advance
Gord
Re: tranmission prices
« Reply #1 on: July 30, 2006 - 11:16:01 PM »
800 or more depending on condition
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: July 31, 2006 - 07:07:41 AM »
More!   :money:
Offline moper
« Reply #3 on: August 02, 2006 - 05:55:11 AM »
A blown up core will go $4-500. A good one will go for 2-3 times that, depending on body style. B/E units (really only a tail shaft swap) are the biggest dollar ones. Earlier B stuff isnt as bad. But, in terms of strength, a 23 spline will hold very close to the same power.
Offline moparnut
    • My Photo's
« Reply #4 on: August 07, 2006 - 08:28:21 AM »
I will assume by your name you have a small block,dont use an 18 spline,the 23 will be cheaper and easier to find a bellhousing,plus you dont need it.In fact you can do what i and many others here,get an 833OD out of a 80-90's dodge pickup,same tranny but 4th is overdrive.They have to pads for both B@ E body shifters,you may have to drill the pads and tap for the E body mount but thats easy.Its aluminum case which save wieght as well
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline Aussie Challenger
« Reply #5 on: August 12, 2006 - 08:35:11 AM »
I will be looking for a 4spd, how plentiful are the 833OD units and what could I expect to pay for one. I will be converting my '70 Challenger from a 904 and realise that many other parts are required. Will the Hurst pistol grip shifter bolt up to one of these 4spd's. If I get one with a bellhousing and fittings can they be adapted to a Challenger?
