Author Topic: Let's play "Name that steering box"!  (Read 1766 times)
Offline Grec
Re: Let's play "Name that steering box"!
« Reply #15 on: July 31, 2006 - 12:01:43 PM »
OK.  So it sounds like this pump, although incorrect for a 440, could be made to work by simply replacing the small block brackets with the big block type, right?
Also, what's the difference between a small and big block pump? Is the big block pump a bit stouter to compensate for the extra weight of a heavier motor?
If that's the case, I may just wait for the correct pump to come along rather that have an inadequate pump get overworked.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline ShelbyDogg
« Reply #16 on: July 31, 2006 - 12:44:40 PM »
The difference is in the brackets. But I usually see the complete setups (pumps and brackets) at the swap meets. If That's a good pump cheap, get it.
Offline Grec
« Reply #17 on: July 31, 2006 - 01:14:07 PM »
Right on.
Thanks!
- 440 Six Pack
