A518 Overdrive Questions
Author Topic: A518 Overdrive Questions  (Read 148393 times)
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
Re: A518 Overdrive Questions
« Reply #180 on: February 25, 2008 - 02:11:20 PM »
I just ordered one for $29 + freight + tax.   I also just found this kit at Summit from TCI.  Its perfect for our needs, looks like it needs another pressure switch for OD, but pretty nice.  Not cheap, but not crazy either.
TCI-376600
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TCI%2D376600&N=700+400252+115&autoview=sku
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
« Reply #181 on: February 25, 2008 - 02:22:42 PM »
Here is there description,
Universal Lock-up Kit
Installation of this kit makes retrofits into non-ECM 700R4 or 2004R vehicles a snap. System allows automatic operation of the TCC in 4th gear under stable engine operation, and disengages the clutch when accelerating or down shifting. Also provided in the kit is a manual override option. Constructed from OEM connectors and oil resistant wire, we install this kit in all our complete 700R4 & 2004R StreetFighter® Transmissions.
Description  Part No.
Lock-up Wiring Kit 376600
Replacement 2-wire TCC Solenoid for 2004R/700R4 376601
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline tactransman
« Reply #182 on: February 25, 2008 - 02:24:30 PM »
I seen that,it is for a GM 700R4 (nice kit for installing one of those in a GM) it really has alot of stuff that we don't need,and it lacking some stuff that we do need.
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #183 on: February 25, 2008 - 02:25:49 PM »
Did you order one from Trans Center at that price?
Terry-tactransman
Union, Mo.
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #184 on: May 11, 2008 - 09:12:10 AM »
Looks like more work than I thought!  :faint:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #185 on: May 11, 2008 - 06:07:51 PM »
Very interesting!  Thanks for documenting this install.  I am sure it will help a bunch of people.   :2thumbs:
« Reply #186 on: May 14, 2008 - 07:26:23 PM »
Dogg thats a really interesting dilema.  I hadn't heard that the trans crossmember interfered with the speedo cable.  I plan on installing a VSS from an 89 truck, which will really make it a PIA if you can't get it away from the crossmember.  I find it kind of hard to believe that moving the motor back all of a 1/4" will make much of a difference in that clearance.
But its a good idea to move it back just for weight distribution anyway.  I've heard that you can angle the original shaft and just mock up a lower pivot point for the shaft to get it away from the trans body and it will still work fine.   This is from 1WildRT out in Cali, that did it to Ransom's 70 vert.
Thats what I'm going to try.  If that don't work, I've been looking at some cable shift options
Let us know how it progresses.
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline ntstlgl1970
  • T a c o c a t
« Reply #187 on: May 15, 2008 - 02:06:49 PM »
how about if you were to move the lower pivot point on the trans case forward and use either the boss where the 2wd strut rod attaches (boss behind the cooler return fitting) or the service boss just forward of the cooler return fitting to attach your lower mounting bracket to. Both of these bosses have a lot of material that could be drilled out for a plastic bushing. Then make the rod from the shifter longer and the rod from the bellcrank shorter accordingly. I think the center console would still cover the access hole where the bellcrank would go through the tunnel.
« Last Edit: May 15, 2008 - 02:11:25 PM by ntstlgl1970 »
Offline tactransman
« Reply #188 on: May 15, 2008 - 02:09:51 PM »
Keep working on this guys because my 518 WILL be going in this summer.  :lol:
Terry-tactransman
Union, Mo.
Offline ntstlgl1970
  • T a c o c a t
« Reply #189 on: May 15, 2008 - 04:06:00 PM »
I already had put a 4 speed hump in mine so I'll have some extra room to work out the shifter stuff, I would like to run the slap stick also with a stock or slightly modified console as opposed to the hurst dual gate I was running before
Offline Jacksboys
« Reply #190 on: May 16, 2008 - 01:19:33 AM »
I found a link to the brackets to bolt on the cable at Rocket Industries here:
http://www.rocketindustries.com.au/search.php?menu=Shifters+%26amp%3B+Accessories
Which bracket were you looking at: BM10494 or BM10499?
Offline Jacksboys
« Reply #191 on: May 16, 2008 - 01:01:39 PM »
BM10499 (front pull)  would be the easiest to install. I've always used front entry cables since they are easy to install away from the headers. The front entry would also work better to connect for the "push forward for PARK" Slap-stik shifter.
Okay thanks   :2thumbs:
Offline ChallengerHK
« Reply #192 on: May 16, 2008 - 02:50:29 PM »
  Never say "keep it forever"  right?
Owner since 1978 and counting  :bigsmile:. Nonetheless, a definite thanks for this effort. I'm paying close attention.
- Han Solo, Star Wars
Offline Jacksboys
« Reply #193 on: May 21, 2008 - 02:30:27 AM »
Sweet, that is looking great Rob.  I was just wondering: Would there need to be some type of coating on the tranny to keep the linkage from wearing a hole from vibration?  Also, does that setup still clear the floor?
Thanks for all of the hard work finding a way to make this possible.   :2thumbs:
Offline Jacksboys
« Reply #194 on: May 22, 2008 - 01:22:26 AM »
The lower mount will keep the rod from touching the tranny. There is enough room to pass between the hump and the trans.
 It is even with the torsion bar so it shouldn't hit the floor.
Sounds great   :2thumbs:
