A518 Overdrive Questions
Author Topic: A518 Overdrive Questions  (Read 148401 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: A518 Overdrive Questions
« Reply #195 on: May 23, 2008 - 02:37:37 AM »
 :woohoo: :bananasmi :woohoo: :bananasmi :woohoo: :bananasmi
ROB, YOU ARE THE MAN!!!!!
That is a sweet setup.  Just think, you are the first person to prove that it can be done.
One question: I know yow are doing this with an A518, should it be the same for the A500?
Offline tactransman
« Reply #196 on: May 23, 2008 - 08:14:29 AM »
The OD section/housing on a 500 is the same as a 518.
Terry-tactransman
Union, Mo.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #197 on: May 23, 2008 - 08:17:03 AM »
Sweet thanks for the info...
and "Just think, you are the first person to prove that it can be done."
Now can you lower the price of gas?   :smilielol:
Go Fast & Have Fun...
    • THE DODGE BOYS
« Reply #198 on: May 23, 2008 - 10:42:35 AM »
are you going on the power tour?
    • THE DODGE BOYS
« Reply #199 on: May 23, 2008 - 10:53:31 AM »
If you go to Topeka you could save on the shipping of some shifter rods :o
I live in Gardner KS and will be in Topeka on the 9th.
I could let you tune my 6.1 also   :scared:
Offline ntstlgl1970
  • T a c o c a t
« Reply #200 on: May 23, 2008 - 12:39:21 PM »
Okay,  It's done.  It shifts perfect because it is using the stock arm.  When I bought the junk yard 518, I took the little bracket in the pic.  I cut it at the bend, cut it to length, then welded it back together to hold the bottom of the rod. I bent the bracket a little to hold the rod at a 90 degree angle.  I haven't decided to keep the 518 or convert it to a 4 speed yet, but I now know it can be done.    The speedometer nut can be mated up by grinding the corner a little. I don't see what the big deal was all about.
That's cool! The big deal is that no one was determined enough to make it happen.
 :thumbsup:
    • THE DODGE BOYS
« Reply #201 on: May 23, 2008 - 02:43:33 PM »
looks like my co-pilot (son) has to be back at Mizzou by Monday morning, which is Topeka day. We'll probably drive home Sunday Night from Springfield MO. I can't see spending any more on gas when I need parts for my 2 projects.
ok thats cool I understand the gas deal and needing parts. Thats why I am only doing Topeka (gas prices and my car is not ready)
What will you be driving?
Offline leanburn
« Reply #202 on: May 26, 2008 - 02:58:29 PM »
looks like i'm going for it. ive been reading this thread for past couple months. i found a tranny guy in edmonton that came highly recomemded and is up for the challenge. i'm taking the car to him mid next month, i'll let you guys know how it goes.
Offline leanburn
« Reply #203 on: May 26, 2008 - 03:01:15 PM »
oh yeah........... i'm looking for a core in the edmonton area.
Offline tactransman
« Reply #204 on: May 26, 2008 - 06:20:15 PM »
Are you going LU or NLU? NLU's are very hard to find.
Terry-tactransman
Union, Mo.
Offline leanburn
« Reply #205 on: May 26, 2008 - 06:41:52 PM »
i'm trying for a nlu for the reason of going with a higher stall but my tranny guy seems to think you can custom build a lockup to get what i want, i also talked to another guy and he says you can use a nlu converter in a lu tranny. the guy thats going to do the work is going to tune into this thread sometime soon.
 i'm worried about going to high on a stall, since i do lots of bracket racing i would like to be in the 3000 range but when i hit the highway i'm going to be slipping arn't i?
 with 411's and 28'' tires can anyone tell me what my rpm would be at 60 to 70 mph with a nlu?
Offline tactransman
« Reply #206 on: May 26, 2008 - 09:42:09 PM »
A non lock up and lock up will NOT interchange,the spline count for the input shaft is different. I have a NLU that it took me 2 years to find for a core. I wanted a NLU so I can go to a like a 4500 stall if I want to. I have not seen high stall LU converters,nor would I trust a LU converter for a car going to the track on a regular basis. The internals are weaker due to having to save room for the LU clutch.
With 4.11 gears you would be fine with a 3000 stall.
Terry-tactransman
Union, Mo.
Offline ntstlgl1970
  • T a c o c a t
« Reply #207 on: May 27, 2008 - 12:17:13 AM »
I did some surgery to fit my 618 on my car over the weekend - http://www.cuda-challenger.com/cc/index.php?topic=37642.msg462502#msg462502
Offline Jacksboys
« Reply #208 on: May 28, 2008 - 11:12:04 AM »
I've seen the 500 in the junk yard but passed them up because I was hunting 518s.  The smaller size "should" make it easier for you to do the same thing.  You'll probably have an easier time with the speedometer too.  With gas prices the way they are now, I would put in the lock-up style converter 500, if that is the one that you have in storage. (3 pin connector).
Yep, the 500 lock-up is the one I have in storage.  Now I have to find a local transmission guy that will go through my 500 for a decent price.
One more question; Since I am using a stock 318 converter in my Challenger, should I be able to use one of the cheaper converters that Mopar offered for the Dakota, like one of these:
lock up performance econo converters for 904
4529403AB  68-92 904/a500 1900-2100 stall  249.00
5007290AB  68-92 904/a500 2250-2350 stall  239.95
P5007291AB  1993–96 A-904 1900-2100 Stall  239.95
P5007292AB  1993–96 A-904 2250-2350 stall  249.95
Also any clue what is the difference between the years?
Thanks  :2thumbs:
Offline tactransman
« Reply #209 on: May 28, 2008 - 12:01:35 PM »
What year is your 500? '92 they did a pump/gear change(slots or flats on the hub)
Flats
Slots
« Last Edit: May 28, 2008 - 12:15:59 PM by tactransman »
Terry-tactransman
Union, Mo.
