I went a little different way with my build. I ended up with a 03 5.7 hemi instead of the pedestrian TBI 318. So now I'm concerned that the tranny may not hold up too well behind the hemi with a cam.
I decided to paint the car while I had the motor out, so I have the car stripped to a thousand pieces, and my body/paint shops backed out on me. So Its sitting at a friends place and I need to find a decent paint shop near Austin Tx, anyone have any suggestions that put me in the poorhouse?
I don't suppose you can tell via a pressure check if there is enough fluid getting to the OD bearings can ya? How far do I need to tear down the trans to check to see if it has that hole drilled in the tailshaft?
Thanks Terry,
Chris
