Author Topic: A518 Overdrive Questions  (Read 148427 times)
Offline ragtopdodge
Re: A518 Overdrive Questions
« Reply #270 on: July 14, 2011 - 07:32:53 PM »
Yah, I'll take either lockup or non-lockup.  I'm not building a big monster HP 383 in front of the 'Cuda so lockup will work and probably what I prefer if it'll lower RPMs lower than a non-lockup for even better gas mileage.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #271 on: July 25, 2011 - 04:25:10 PM »
Hummmm interesting post!  :naughty:  Thanks all! :2thumbs:
Offline ChallengerHK
« Reply #272 on: July 26, 2011 - 08:58:18 PM »
I recall Robb saying that he was able to fit his 518 with no mods to the trans tunnel by fabbing a trans mount to lower the trans. Am I making this up? Or, if it's right, can you tell me how much lowering needs to be done, Robb?
- Han Solo, Star Wars
Offline ShelbyDogg
« Reply #273 on: July 26, 2011 - 11:05:02 PM »
Page 1 of this thread above.  I cut the rib on the tailhousing to fit the trans up to the original angle of the drivetrain. A custom trans mount can then be welded up to hold it in position.
Check this website for the wiring and transmount under "other modifications"
http://www.transmissioncenter.net/SwapInformation.htm
« Reply #274 on: July 26, 2011 - 11:15:03 PM »
Anyone know what a 518 weighs in at? Compared to a 727?
« Reply #275 on: July 26, 2011 - 11:19:29 PM »
Thanks, Rob. I take it that the tailshaft isn't seeing enough torsional stress that removing that rib section poses a problem?
Offline ShelbyDogg
« Reply #276 on: July 27, 2011 - 12:26:34 AM »
I don't think removing that section would weaken the tail housing much. That thing was used in big vans and we are using it in cars.
Brad, when I raced, I could R&R my 727 with pure muscle. That was my limit. When I pulled 2 518s at the junk yard, I had to ask a passer by to help me lift it into my wheelbarrow. I thought it was going to explode my nards.
« Reply #277 on: July 27, 2011 - 08:33:27 AM »
 :smilielol: Never heard it put like that, but I get the drift!  :roflsmiley:
A buddy of mine was a tranny mechanic at a local Mopar dealer. He has a few of these laying around his garage.Along with lots of parts.  That was his biggest beef using it in the Challenger ( too heavy) as compared to the GM 4L60 .( that's what he said he would use?) Another thing to watch out for he said was the cooler lines were to small on certain years and they didn't last because of it.
I'm having trouble deciding what to go with?  5K for the Keisler set up is about 2K too much IMO . The 518 is too heavy. I might just rebuild/freshen up the 727 with parts my buddy has and a new kit? Don't know yet? :pullinghair:  still reasearching.......
Offline tactransman
« Reply #278 on: July 27, 2011 - 09:24:37 AM »
It had nothing to do with the size of the cooler lines,cooler line size has been the same on the 46RH/E series transmission since it came out in '90 (3/8) It was a lube problem (inside the trans) and too small of a bearing for the load (inside the trans) They added an extra lube hole and went to a bigger bearing around '93-'94. Cured the bearing failure problem. The biggest "melt down" problem I see now is when the converter clutch comes apart (very common on the OEM converter) that material blocks up the trans cooler and then makes a BIG mess inside the trans!
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #279 on: July 27, 2011 - 11:23:38 AM »
Just remember that the 500 and 518 are for small blocks and using them behind a BB requires an utra-bell conversion or sending it off with a 727 to have that other company convert it for you.  Brad, I see that your combo is a 440/727 so your case conversion is a must. Still cheaper than a 4l60e.  If you check that link I added above, they put a 518 in a Dart.
« Reply #280 on: July 27, 2011 - 12:29:55 PM »
Have you ruled out Gear Vendors? I know Carlwalski had problems with them, but he had very specific things he was trying to get it to do (a split/shift six-speed), and it seems like, just for getting overdrive, it worked perfectly.
« Reply #281 on: July 27, 2011 - 12:55:14 PM »
Thanks Terry good info!  :2thumbs:
« Reply #282 on: July 27, 2011 - 12:56:41 PM »
 True! The 518 is looking les and less like an option for me.
I'm going to be starting a 451" soon to replace the 440.
« Reply #283 on: July 27, 2011 - 12:57:40 PM »
I hear that's expencive too. and you have to cut up the floor. :eek4:
Offline ragtopdodge
« Reply #284 on: July 27, 2011 - 01:48:45 PM »
Ultrabell is ~$400.  NOt bad IMHO plus it will help strengthen the unit.  Looks pretty straightforward to install:
http://www.banningcohen.com/buick/th400/index.htm
06 300c SRT8
04 2500 QCLB 4x4 HO
