Author Topic: A518 Overdrive Questions  (Read 148430 times)
Offline ragtopdodge
Re: A518 Overdrive Questions
« Reply #300 on: December 16, 2011 - 11:11:05 PM »
I went ahead and found me a 2-pin non-lockup for $150 near me!  Only had 60k on it, but it'll get torn apart anyways.  :clapping:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline tactransman
« Reply #301 on: December 19, 2011 - 07:14:43 AM »
Good price!  :2thumbs:
Terry-tactransman
Union, Mo.
Offline RCCDrew
« Reply #302 on: January 05, 2012 - 08:50:13 AM »
One of the articles I read recently said that you could get away with running a much "looser" convertor with a lockup style convertor.  Any opinions on this?
Offline Cooter
    • christinecarclub.com
« Reply #303 on: January 05, 2012 - 12:30:02 PM »
Although I haven't personally done it, stands to reason you could run a 4500 Stall on the street, as long as it's locked up like a manual. I have however, tried to drive a 4500 Stall on the street with NO lock up and lemme tell ya' it will burn fluid within the first 30 miles. Oh sure, you'll sky the tires with any real traction, but the trade off isn't worth it IMO.
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #304 on: January 07, 2012 - 09:35:16 PM »
can i but an a 518 behind a 383 in a 74 cuda/
Offline GranCuda1970
« Last Edit: January 07, 2012 - 09:48:17 PM by GranCuda1970 »
Offline tactransman
« Reply #306 on: January 07, 2012 - 10:38:59 PM »
On this link http://www.hotrod.com/howto/43323_mopar_overdrive_transmission_swap/
I have talked to John Vinson at JVX many times on the phone and he knows his stuff!
Terry-tactransman
Union, Mo.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #307 on: January 09, 2012 - 10:10:00 AM »
Its not as straight forward as with a smallblock, the 518 was never built for a big block.  You need cut off the bellhousing, and bolt on a aftermarket one designed for bigblock.  There is a good thread on Moparts with a guy doing it for a truck.
You'd probably be better off with a good 727 and a Gearvendors overdrive.  It will cost about the same if your buying everything from a dealer and having it installed.  Its a bolt on (no fabricating) and you can take it off again if you wanted to.  The reduction in labor alone is worth it, plus its supposed to be good up to 1200 HP.  It also has a 2 yr warranty.
I have a friend with one in his Sebring and he loves it, it just works and he doesn't have to think about it.
I by the way, am installing a 518 in my Challenger....someday.   I've had all the parts for years now, but its still not in and running.
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline Katfish
  • 70 Challenger
« Reply #308 on: February 16, 2012 - 09:52:11 PM »
Found this thread way late, but
Has anyone posted a complete how-to on the SB/518 swap into an E-body?
Does the floor pan need to be cut?
 :popcorn:
Offline rockymopar
« Reply #309 on: February 16, 2012 - 11:07:52 PM »
This is the definitive source, this very thread. There are 20 pages or so. If you want to do the swap, page thru all of them. Basically, you have a couple of big frankenstein like lugs on the pass side to cut, and you have to notch some fins by the speedo cable. 10 minutes with the sawsall. Presently, you have to fab your own crossmember. I am trying to deal with us all the 5 speed conversion dealers as I think their crossmembers may be adaptable to the 518. I made my own out of scap steel, and it still looks like scrap
« Reply #310 on: February 17, 2012 - 07:13:54 AM »
Offline Katfish
  • 70 Challenger
« Reply #311 on: February 17, 2012 - 07:42:10 AM »
That's awesome, would love to see something similiar for SB e-body.
« Reply #312 on: March 31, 2012 - 12:22:27 AM »
That is a great thread, there is just a lot less work for a small block.   I guess I'll need to read through this thread again, because I thought this was a great thread for installing a 518 to a small block in a Ebody.... :clueless:  Maybe its not as complete as I thought.  I'm starting my assembly (again) so I probably need to go over it again anyway.
« Last Edit: March 31, 2012 - 12:25:28 AM by PlumCrazyChris »
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline Katfish
  • 70 Challenger
« Reply #313 on: March 31, 2012 - 12:44:25 PM »
Ok PlumCrazy, I'm right behind you.
Make sure you take tons of pics and document every step.  Seems like we need a vendor to step up and put together a kit, or at least the tranny support.
Offline ntstlgl1970
  • T a c o c a t
« Reply #314 on: March 31, 2012 - 06:53:16 PM »
You can modify the stock trans crossmember and make it work, cut the trans mount "ears" off the front and weld a new mount on to fit a gm biscuit trans mount, elongate the trans mount to trans holes and it pretty much bolts together. That's what I did on mine.
