Thanks Terry.... taking orders..
It does fit in Ebodies and 71 and up Bbodies without cutting the car. I did have to dent my torsion bar crossmember slightly to allow the speedo cable easy access, and pounded the tunnel/floorpan some to add a little clearance, but its not significant.
One issue you'll have FF6849 is the fact that you want to hook this up to a big block. These transmissions were never made to connect to a BB. So that will require some additional work to cut off, and then bolt on an adapter bellhousing. There is a great thread on Moparts from a guy that did this several years ago. It turned our great for him.
You can keep the stock linkage pretty easily actually. I thought it was going to be a hassle, but there was nothing to it. If you get a pivot bracket from a column shifted car, (its L shaped with a bolt pressed in one end and a pivot hole and bushing in the other) you just pop out the bolt (protecting the threads) and pound it flat in the vice, then put the bolt back in. My trans has a handy little tab sticking out that I bolted it through near the shifter linkage, and the other end is perfectly positioned to accept the (once vertical) now angled pivot post from the shifter. Then hook up your shift linkage as usual and your done. It was really pretty easy.
Check out the thread on Moparts for the big block to see what you'd be in for. For us smallblock guys its a no brainer, especially with a new do it yourself trans crossmember....
