A518 Overdrive Questions
Author Topic: A518 Overdrive Questions  (Read 148499 times)
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
Re: A518 Overdrive Questions
« Reply #330 on: November 07, 2012 - 10:02:47 PM »
Yes your kickdown stays the same with a carb.   I am using a cable from Lokar.
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline ff6849
« Reply #331 on: November 17, 2012 - 12:00:45 AM »
Saw this modifation on moparts do you all think that this ok or I am asking for problems cutting the into the cross member this way
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline 360FISH
  • BS23H3B567746
« Reply #332 on: November 17, 2012 - 01:36:16 AM »
You don't need to do any of that...
read this:  http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Don't have to touch the car...
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
« Reply #333 on: November 21, 2012 - 12:37:59 PM »
Thats right, you don't have to cut the car at all,  just make a new trans support crossmember.   I did use a hammer and banged a little clearance so it didn't knock on the floor, but it really wasn't mandatory.
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline ff6849
« Reply #334 on: November 21, 2012 - 04:51:44 PM »
Found one ........so it will begin I will start to gathering the parts, adapter plate (going behind a 440), rebuild kit, TC, pressure switch kit, and any other misc items. Goal is to have it done by summer.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline rb70
« Reply #335 on: November 21, 2012 - 10:36:40 PM »
since you got a truck tranny, you will need to change the govenor, PATC told me about this and you will need to get one that is for a car. Also ,measure your driveshaft carefully, when I had mine cut, I took off about a 1/2" to much off. Also the 46rh TQ convertors are neutrally balanced.
Good luck!!
Offline tactransman
« Reply #336 on: November 21, 2012 - 10:53:27 PM »
Good luck!!
PATC is wrong on the governors, there is no difference. 46RH converters are not all neutrally balanced either, depends on the engine.
Terry-tactransman
Union, Mo.
Offline Adrian Worman
« Reply #337 on: November 23, 2012 - 04:36:40 PM »
Since its out and easy to service when you whip off the sump to change the filter drop the valve body and check the band adjuster wedges, I've had them break and fall onto the valve body jamming the shift comb, on these trans in Ram 250 vans before, worth an inspection : )
Offline 360FISH
  • BS23H3B567746
« Reply #338 on: November 24, 2012 - 04:33:06 AM »
It is well worth the rebuild kit (and super easy to do) on the front end of the tranny...  maybe get some help and put in a shift kit too.  :)
Don't mess with rebuilding the OD unit unless you know what you're doing.  dangerous.
Offline ff6849
« Reply #339 on: November 24, 2012 - 09:47:56 AM »
don't worry a total rebuild is in the works, and by a real transmission guy too, I am going to upgrade everything I can. I am figuring about $1000.00 kit with a 2500-2800 stall TC
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
