Author Topic: A518 Overdrive Questions  (Read 148512 times)
Offline Carlwalski
Re: A518 Overdrive Questions
« Reply #30 on: July 31, 2006 - 09:25:29 AM »
Sweet. Thanks TTman. I will keep an eye out for a 1990 A518 case in need of a rebuild.
When I find one I'll email or PM and we'll take it form there. I'd have it shipped directly to your shop.  :cheers:
Had a look at your website, didn't realise it was such a professional outfit (no offense of course).
Is that you on the main page?
 :2thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Carlwalski
« Reply #31 on: July 31, 2006 - 09:48:57 AM »
Great work Shelby.  :cheers:
Terry, before I commit and forward you any money I want to double check with my resto team.
I'll let you know when I'm good to with your consent.  :swaying:
Offline tactransman
« Reply #32 on: July 31, 2006 - 09:49:13 AM »
I won't pay that much for a core, partly because the car is all apart(no hurry) and I am hoping one will come thru my door here with someone wanting to get a core out of their way. What about the
"U wrench it" place you were talking about earlier? All I want is a buildable core , not one with a warranty that it works or anything. :thumbsup:
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #33 on: July 31, 2006 - 09:50:30 AM »
Sounds good NZ , if we get serious about this we can talk more. :thumbsup:
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #34 on: July 31, 2006 - 09:52:37 AM »
Yep  :22yikes:  that is the transmission I built for my Challenger
 :2thumbs:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #35 on: July 31, 2006 - 10:01:07 AM »
Awesome, and I'm dead serious. Your prices can't be beat and you know your stuff.
Besides, it'll be cool to have a board member build me a custom OD trans.
I'll let you know via this thread as soon as I know what my exact plans for the Cuda are.
If you like, you could do me a favor......could you get a couple of shipping quotes for me?
From your shop to Wellington, New Zealand post code 6007.
Using any of the big name companies. Try EXPRESS, a second rate shipping and the slowest.
Just this way I know where I stand with shipping from the start and can then get a better gauge on the overall cost and money expenses. If you could that, that would be awesome. Hopefully someone in your customer service center could get a couple of quotes together.
Cheers,
Carl
Offline tactransman
« Reply #36 on: July 31, 2006 - 10:03:11 AM »
 :2thumbs:
No offense taken, I am a small shop (2 bays and one young guy working for me) I am probably going to add two more bays next year. I do alot of 727's and a few 904's and alot of 518's. Quality control is excellent though with me being the only one doing the rebuilds. I am going to get a customers cars tab added to the web site soon so everyone can see my clientel. :thumbsup:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #37 on: July 31, 2006 - 10:06:48 AM »
Sounds like a good work ethic goes on there Terry, good for you mate! If I lived in the States I'd probably ask for a job with you so I could learn a thing or two in a subject (Performance Autos) I like.
What are the pros and cons of lock up vs non lock up? Basically I'm wanting the best.
I want something reliable, long lasting, heavy duty with good performance. Is this possible all in the same trans.
My resto guy said he prefers non-lock up but didn't give me any reason why, this was because it was over the phone and a second rate comment that I asked needing either a yes or no answer.
Offline tactransman
« Reply #38 on: July 31, 2006 - 10:23:34 AM »
A non lock up you are unlimited on a converter(stall and strength) a lock up will drop your RPM about another 300 but they are limited on stall , more expensive and not as strong (the lock up clutch and mechanizm take up room on the inside)
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #39 on: July 31, 2006 - 11:01:37 AM »
So you recommend non-lock up.  :swaying:
Offline tactransman
« Reply #40 on: July 31, 2006 - 11:09:40 AM »
Yes , if you are going to have a pretty strong engine in front of it . If you are going to just criuse like Shelbydogg than a lock up is fine. The rule of thumb on any automatic overdrive is if you are going to run a 3.55 to 3.73 gear or numerically higher rear end ratio , you do not have to have a lock up. Anything lower (3.23 example) than you need a lock up to eliminate the heat in the converter when in OD. I want my car to run 11 second 1/4's with the 518 so I am going with a non lock up and a 4000 to 4500 stall with 4.30 gears. :cheers:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #41 on: July 31, 2006 - 11:20:12 AM »
Sweet! I should be fine with a non-lock up.
The only reason I'm getting a A518 is because I want to replace my 3.23 gears with either 3.91s or 4.10s+.  :thumbsup:
Offline tactransman
« Reply #42 on: July 31, 2006 - 12:43:22 PM »
I'll try to find you a newer 518 in MO. What was the cutoff year terry? 95?
1996 and later they went to computer upshift.
Terry-tactransman
Union, Mo.
Offline EVIL72
« Reply #43 on: July 31, 2006 - 08:12:55 PM »
 So a 518 non lockup trans WILL work fine in overdrive with a 4000-4500 stall converter? Does it just need a huge trans cooler to keep the heat down?
 So how much HP and torque can an all out built 518 handle?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline tactransman
« Reply #44 on: July 31, 2006 - 08:34:45 PM »
Yes , especially since my Challenger will have 4.30 gears in it. :burnout:
Yes a good cooler
In my opinion anything a 727 can handle.
Terry-tactransman
Union, Mo.
