Other than the previously mentioned issues, I like the overall look of the parts in the 512 kit. I have talked with the guys at 440Source about my problems with the main cap and they have been very receptive to working everything out with me. They even gave me a call one day to let me know that they had been having some issues with the adjuster studs on the same particular rocker arm sets that I had got from them with my stroker kit order. They wanted to just confirm my shipping address so they could send me the updated adjusters free of charge. From my dealings with those guys, they are on my good guy list for any future purchases.
As far as specs go, keep in mind this engine is not completely finished yet and this stuff/specs may change:
- '75 440 block magged, tanked and line bored (for new main caps)
*from 440Source* - 4.250" stroke crank
- +.055" custom Ross pistons
- 7.1" H beam rods with 2.200" (Chevy) big end and .990 small end
- Clevite "V" series bearings to clear larger champher on new crank
- Childs&Albert Zero Gap rings
- 1.6 Stainless Steel roller rocker set with new shafts (no longer available)
- billet steel dual roller timing chain kit with torrington roller thrust bearing
- billet stainless steel SFI damper
- billet steel main cap set (a note about the required additional machine work is now on their site)
- ARP stud kit for main caps
- Melling high volume oil pump
- complete stainless steel engine/freeze plug kit
*from Indy Cylinder Head*- 440-SR CNC 295 heads with full CNC port and polish and Max Wedge port size (includes ARP bolts and external oil lines)
- 440-2 single plane intake
- 440-6R aluminum valley cover plate with access panel
- 440-7 cast aluminum valve covers with Indy logo
- 2.125" ceramic coated TTI step headers for 440-SR heads
- 509SW Comp Cams (I think?) hyd cam and lifter kit
- custom cut to fit pushrod kit
- 850cfm Street Demon, vac sec with electric choke
- CSR Proflo aluminum water pump housing
- CSR electric water pump unit
- MSD Billet Distributor
- MSD 6AL
- MSD Super Stock coil
- MSD Super Stock plug wires
*other stuff from other places*- cheapy chrome auto parts store air filter and tins (just temporary till I make a base plate to make the T/A hood functional)
I know there's more but I can't think of anything else at the moment. The engine is in PA with my car and I'm over here in Puerto Rico. Kinda makes it tricky when I want to check anything out on the car or engine ya know
