Author Topic: condensor  (Read 6809 times)
sleepychallenger
condensor
« on: July 31, 2006 - 11:23:33 AM »
does anyone know the function of the condensor on the back of the rallye gauges?
Re: condensor
« Reply #1 on: July 31, 2006 - 03:30:07 PM »
You are taking me back a few decades here, but it is used in this case as something to smooth out the voltage to those smaller gauges.
Offline PlumCrazy
Re: condensor
« Reply #2 on: July 31, 2006 - 11:45:58 PM »
Radio Noise Suppresion. also on the ignition coil and in the alternator.
sleepychallenger
Re: condensor
« Reply #3 on: August 01, 2006 - 10:53:17 AM »
will that cause the guages to not fully read where they are suppoesed to or to fluctuate each time I start the car?    :dunno:
Re: condensor
« Reply #4 on: August 01, 2006 - 03:43:06 PM »
Please tell me you are NOT going to try and go without one.  :scared: It's there for a reason. Your readings will never be true. If you are in serious need of one, I have an extra.
Offline PlumCrazy
Re: condensor
« Reply #5 on: August 02, 2006 - 01:00:08 AM »
It could... but I would check grounds before replacing parts.
sleepychallenger
Re: condensor
« Reply #6 on: August 02, 2006 - 07:24:19 AM »
no, im not going without. what part do I ask for when I go to the parts store. mine is hooked up still but not sure that it is working. when I put it all back together the first 3 times of running the car the guages just went up and down all the time (all the way up then all the way down). Now the temp guage slightly moves on the C, the oil guage reads correct sometimes and low other times, the fuel guage reads 1/2 tank when I fill up all the way. I just want these things to start working correctly. Does anyone have the scamatic for the dash wiring. No A/C, one speaker, Rallye dash. Maybe I can chase down some issues.
sleepychallenger
Re: condensor
« Reply #7 on: August 05, 2006 - 10:29:50 AM »
anyone?
Re: condensor
« Reply #8 on: August 05, 2006 - 10:43:39 AM »
the voltage regulator pulses 5v to the guages possibly the regulator is bad
sleepychallenger
Re: condensor
« Reply #9 on: August 07, 2006 - 06:13:38 AM »
brand new voltage regulator.  condensor has not been replaced
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
Re: condensor
« Reply #10 on: August 07, 2006 - 06:20:06 AM »
Like drawing #2 above shows, it's a voltage limiter for the gauges and yes they do go bad and display the symptoms you described. I had to replace one in my 71 Duster.
Offline PlumCrazy
Re: condensor
« Reply #11 on: August 07, 2006 - 01:02:53 PM »
Just unplug it and see what happens.
sleepychallenger
Re: condensor
« Reply #12 on: August 14, 2006 - 06:48:07 AM »
I replaced the limiter already and when i unplug the condensor nothing happens
Re: condensor
« Reply #13 on: August 14, 2006 - 07:15:12 AM »
solution to voltage limiter problems
http://www.allpar.com/history/mopar/electrical2.html
The condenser I believe is to cut down on radio interference, basically a noise suppressor.
sleepychallenger
Re: condensor
« Reply #14 on: August 14, 2006 - 01:05:49 PM »
anyone have anymore ideas. the guages are not fluctuating while the car is running. the only fluctuation is the oil guage and that is from each time that the car is started it ends up in a different location. It does move when I come to a stop it will drop  then when i move it will go up. I just want the fuel guage to go to full when I fill up instead of half a tank and for the temp guage to move off of the C and the Oil guage to read where it is suppoesed to everytime. I know this seems like a lot of wants but I find it very reasonable. Please help. If you know where the grounds are so that I can check them please let me know this as well.
« Last Edit: August 14, 2006 - 01:19:28 PM by sleepychallenger »
