I don't think this is a grounding issue. Your temp/gas/ oil pressure gauges get their ground from that black wire coming from the voltage limiter. All 3 are linked together.
Question #1, are you saying the temp. gauge doesn't move at all, even after driving, or does it just stay low?
Question #2, Have you checked out the sending unit to your gas gauge. I have a feeling that might be your problem there. Let me know if you need help in how to check it out.
As for the oil pressure gauge, from your description, it sounds like it is normal. Low pressure at idle, and it climbs some when you speed up.
