Author Topic: condensor  (Read 6808 times)
Re: condensor
« Reply #30 on: September 13, 2006 - 06:40:10 PM »
Lots of folks here have had corosion issues when it  comes to the front turn signals.                                                 Did the Temp issue work out?                     Luck with all !  :popcorn:
sleepychallenger
Re: condensor
« Reply #31 on: September 13, 2006 - 06:54:12 PM »
no, temp guage is still not really working. it does move more but not as much as it should. it doesnt move to the middle range. the parking lights work but not the front turns.
Re: condensor
« Reply #32 on: September 13, 2006 - 08:00:54 PM »
Did you ever try & grounding the sending unit end wire to see if the guage would max out?
Offline Challenger6pak
Re: condensor
« Reply #33 on: September 13, 2006 - 08:23:33 PM »
I think you may have bad sending units.  The oil guage has never worked right and been accurate on any of my clusters.  The fuel and temp sending units may be causing your other problems.  Try grounding each of the sending units and see what it causes in your guages.  Your guages may be fine.  Here's a diagram in case you need it.
« Last Edit: September 13, 2006 - 08:30:37 PM by Challenger6pak »
sleepychallenger
Re: condensor
« Reply #34 on: September 15, 2006 - 12:49:56 PM »
no, I didnt try it. the oil guage is working properly now. the guages were just rebuilt. I replaced the temp guage and it made things better but not correct. I will be replacing the fuel sending unit this weekend. Also, I will be changing bulbs this weekend as well and will let you know on monday how everything turns out. I wont have internet at home until thursday so until then it will be a at work typing. heck, we just got a computer!
