Author Topic: Need carpet positioning info  (Read 785 times)
Offline JeffAARy
  • Orange Mopars Drive Me Wild
« on: August 01, 2006 - 09:25:10 AM »
Where is the rear seam of the forward carpet supposed to overlap the rear carpet in an E-body?  Both of my Cudas got one-piece replacement carpets way back when and I have no point of reference.
-Jeff
Re: Need carpet positioning info
« Reply #1 on: August 01, 2006 - 10:44:03 AM »
I push the front section of the carpet as far forward as possible this puts the seam under the seat in front of the rear seat bolts , I tyr to get the front section to go just up to thebottom of heater box  & cut around the gas pedal & sterring colum , thius should postion the heel pad so it is below the bottom lip of the gas pedal as well
Offline JeffAARy
« Reply #2 on: August 02, 2006 - 09:47:59 PM »
Can someone actually give me a measurement from the back edge of the forward carpet to something known?  I think this carpet is long as I tried putting the leading edge up to the heater box and the heel pad is not under the gas pedal.
