Author Topic: WTB - Fram/OEM 6bbl Air Filters?  (Read 1002 times)
Offline Carlwalski
« on: August 02, 2006 - 01:24:27 AM »
I'm trying to install a hybrid 6bbl air cleaner that fits a 4bbl setup on my 340ci in the Cuda.
We tried a K&N but it didn't fit well at all. The supplier of the Hybrid air cleaner setup said they don't fit well and he said to use a Fram or OEM filter and he promised they would fit like a glove.
So!.........I am needing a stock/OEM/NOS 6bbl oval air filter. Where can these be found?
I see on the Fram website that they have a 1970 6bbl filter for E-Bodies.
Question: Will a 1970 6bbl fit a 1969 air grabber oval setup?
Thanks for any help.  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: WTB - Fram/OEM 6bbl Air Filters?
« Reply #1 on: August 02, 2006 - 06:54:10 AM »
YER BUDDIES AT MANCINI HAVE EM
 MOPAR - Six Pak "A" / "B/RB" engines
New filters made by FRAM for Mopar Performance Parts. These are the correct reproductions with the correct mesh and orange rubber seal
http://chucker54.stores.yahoo.net/airfilters.html
« Reply #2 on: August 02, 2006 - 01:11:01 PM »
same part for both
KTO
« Reply #3 on: August 02, 2006 - 01:58:55 PM »
When it comes time to throw the filter away, cut the original mesh out of it. You can then wrap it around a generic mesh unit... just a trick I've done before.. :)
