Ok, time to put some pics here. My gf has been so busy that our website hasn't been updated for a some while.
I have tons of pictures but I will try to post only most informative ones
This post could be moved to restoration projects section too...
These are some pics of the cowl repair. Both sides of the cowl were totally busted + the firewall edge where the top piece of cowl was spot welded in. I took some liberty to change the cowl construction a bit to get around of that idiotically designed upper cowl meets the lower cowl spot weld edge. Hopefully the it won't gather the debris anymore and the rust keeps away.
Everything was painted with por15 and I will paint the connecting weld from the inside next spring when the weather warms up again (should be doable from the big holes on the top of the cowl with flash light, small paint brush and mayby a mirror).
Upper piece of the cowl was in fairly good condition, although it needed some welding too.
