its been a looong while I have posted new pics and there are very many pictures to show but because the disk space is limited I will post only some so others can post too
hopefully my gf will have time to update our website after she finishes her master of science thesis in one month or so (or what ever it is called).
Ok first set of pics is from the ds quarterpanel, fixing it up and prepping for paint. The wheel lip had many pin holes and even more deep craters where the two metals had been in close contact (inner wheelwell lip & quarterpanel lip). Areas to fix were small in size, large in numbers, so this time that I didn't do any actual patch panels. I just welded all pin holes shut and filled up most of the craters. There were also some small work to do with structure on the upper part of the quarterpanel, where the quarter window comes.
In the end the panel was cleaned up and prepped for paint and I also tried the lead for the first time in my life. Seemed pretty easy to use and much more durable than body filler when correcting bigger bumbs. I don't have good pics from the first led experiment but I will post from the second one bit later.
