Author Topic: Any trick to removing a lower ball joint from a lower control arm?  (Read 4447 times)
Re: Any trick to removing a lower ball joint from a lower control arm?
« Reply #15 on: August 02, 2006 - 05:14:59 PM »
 Bullitt , I have never had to heat it , that is usually not recommended on suspension parts. :cheers:
Maybe My pickle fork is inferior or I just don't know how to use it but I worked myself silly on the upper ball joint till  I used the heat method (on the threded part) + an expanding bolt tool as described in the Dodge service manual, On the lower that nor the fork worked so I got aggressive with the hammer using the bolt thingy as a interim to hit, took about 4 good swings  :thumbsup:
Offline ShelbyDogg
« Reply #16 on: August 02, 2006 - 10:29:21 PM »
A very old mechanic showed me this trick years ago.  I never had to buy a pickle fork. Hold the first hammer firmly against the Tie rod, ball joint, pitman arm, then smash the other hammer into it. It changes it's shape and pops the joint apart.   Leave the nut on a few threads so the part doesn't fall on you.
It works everytime.  Don't use a sissy carpenter's hammer, usa a 2,3,4,or 5 lb baby sledge.
« Last Edit: August 03, 2006 - 05:22:58 PM by shelbydogg »
Offline heminut
« Reply #17 on: August 02, 2006 - 11:08:39 PM »
I've used Rob's method when I didn't have a pickle fork, it definately works! :2thumbs:
1970 5.7 Hemi Cuda
Offline Street_Challenged73
« Reply #18 on: August 02, 2006 - 11:17:05 PM »
I do assume you used the upper ball joint tool for that, right?  I sprayed mine with PB Blaster then hooked that tool up to an impact wrench and had them off in no time flat.  The bottoms were extremely easy as well with the use of a $4 pickle fork from CarQuest. :2thumbs:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #19 on: August 03, 2006 - 05:09:30 AM »
Not to hijack but you can use shelbydogg's technique to open a pretty good size masterlock!  I saw a guy do it with a 4" lock popped right open.  Couldn't believe it till I seen it.  So much for security.  Anyways I bought the jaw type puller  and came right out 20bucks.
Tom
Tom
Offline tactransman
« Reply #20 on: August 03, 2006 - 07:46:17 AM »
It works everytime.  Don't use a sissy carpenter's hammer, 2,3,4,5 lb baby sledge.
Rob, I love your picture!!!! :thumbsup:
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #21 on: August 03, 2006 - 08:09:36 AM »
Thanks Terry,
I'm just bored at work.
I like this one better.
Offline 4Cruizn
  • HEMI FISH
« Reply #22 on: August 03, 2006 - 08:11:20 AM »
Thats attractive!   :faint:
Offline ShelbyDogg
« Reply #23 on: August 03, 2006 - 08:15:55 AM »
Isn't it?
Here is the whole pic, in case somebody want's to do the same to their face.  I'm sure somebody here finds it attractive, and 4cruzin was him.  YIKES.   Let's move it to the BABE thread.
« Last Edit: August 03, 2006 - 08:17:52 AM by shelbydogg »
« Reply #24 on: August 03, 2006 - 09:34:40 AM »
Some parent must be proud.  :pullinghair:
Offline Grec
« Reply #25 on: August 03, 2006 - 11:30:35 AM »
Ugh.
What a frrreak! Gotta be from Berkeley. :-)
Well, I got a pickle fork and my 3lb "mini-Thor" hammer. I'll give that a shot 1st. If it doesn't work out for some reason, I'll go by another hammer!
Cheers.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline tactransman
« Reply #26 on: August 03, 2006 - 11:34:06 AM »
Ugh.
Cheers.
:thumbsup:
Terry-tactransman
Union, Mo.
« Reply #27 on: August 03, 2006 - 12:23:19 PM »
GREC,  HOLD IT, YOU FER GOT THE 20LB BAG OF CUSS WORDS!
« Last Edit: August 03, 2006 - 12:53:37 PM by bullitt99 »
« Reply #28 on: August 03, 2006 - 12:54:35 PM »
Bullit,
Did you just call him a FOGOT?
Not that there is anything wrong with that.   (Seinfeld)
 OOPS  :grinno:
Offline Grec
« Reply #29 on: August 03, 2006 - 06:25:36 PM »
Nope, I didn't fogot. The 20lb bag of cuss words goes without saying. :swear:
- 440 Six Pack
